#1 Speedometer illumination
Posted: Fri Apr 25, 2014 12:17 am
I have never "been behind" the main instrument board, hence my question below. The right side of my speedo seems to have a non working lamp. If I remove the cover underneath the 2 main instruments (2 small cover plates that overlap above the steering column, by the looks of it), can I then fiddle with this non working lamp? or do I have to remove the entire instrument board? It might be a loose connection if not a broken bulb.
I have removed the entire instr boards on two 60s saloons, but that was in the late 80s, when I restored the entire wooden interior of those cars, which I still own. They don?t have the horizontal covers underneath...
Thanks,
Peder
Thanks,
Peder
