#1 Powerlite starter motor noise ?
Posted: Sun Jul 06, 2014 7:50 am
I?ve spent a couple of hundred hours over the last 3 months addressing a whole load of ?mainly detail ? issues, whilst fitting the JT5 gearbox and bell-housing ; however on the eve of a planned 2.000 km jaunt around the Alps I?m wondering if I?ve not screwed something up ??
I got a Powerlite starter motor from Holdens, and believe it to be the right 3.8 version ? correct pinion tooth-count, same diameter as the original Lucas, I checked the fore-and-aft alignment in the thrown-in position, and the lateral mesh felt fine. The JT bell-housing has eccentric oval steel inserts (fabulous machining) which can be switched to cope with other flywheel/pinion variants, but the position I chose seemed to provide the same geometry as the original bell-housing.
I did crank the motor over before re-fitting the engine/transmission to the car and thought it was noisier than expected, but put this down to it being ?on the bench? and unprotected by any of the usual sound-muffling bonnet and body-work.
However now everything is in place (and finished !) I?m concerned that something is not right. The starter fires the car up instantaneously, but the accompanying whine and clunk is way louder than the original Lucas and doesn?t sound right. Indeed, the engine fires so quickly and cleanly that it also sounds as if it?s then driving the starter motor for a fraction of a second before it is able to disengage. If I had to guess from the noise, I?d say it?s as if the pinion/flywheel tooth engagement is too deep.
What impression did others get from using a Powerlite ? Was it quieter, or is the racket mine makes normal ?
PS Am assuming there are no -ve / +ve earth issues here ? I'm still +ve, the starter spins in the right direction, is that all I need to know ?!
