ignition light flickers
marting
#1 ignition light flickers
Post by marting » Mon Sep 01, 2014 4:33 pm
Series 1.5 4.2ltr 1968: ignition light flickers on periodically, alternator is charging the battery normally even when ignition light is flickering.
I would be grateful to hear if anyone has experienced similar and knows what is the cause?
Thank you
Martin :?:
Post by christopher storey » Tue Sep 02, 2014 8:35 am
This is very common indeed, and I really don't think anyone has definitively identified the cause. It can often be improved by cleaning all contacts in the charging circuit, particularly those to earth. In any event , it never seems to cause any problem , but is merely annoying
marting
#3 ignition light flickers
Post by marting » Tue Sep 02, 2014 2:23 pm
Christopher,
Thank you for taking the trouble to reply so promptly.
I will go through all the contacts on the charging circuit as suggested.
Martin Gale
