Removing rear seats on a Series 1 2 + 2
Roger's E Type
#1 Removing rear seats on a Series 1 2 + 2
Post by Roger's E Type » Sun Feb 23, 2014 8:15 am
Hi all,
1966 Series 1 4.2 2 + 2: I need to remove the rear seats to get at the plates that access the rear brakes. The cushion comes out easily but how do I remove the sliding seat back rest - I think it is called the squab?
Cheers,
Roger
Post by PeterCrespin » Sun Feb 23, 2014 2:00 pm
Two bolts in the base plate of the parallel linkage each side. It's a fairly heavy item so don't do your back in reaching over to lift it.
mystery type
Post by mystery type » Sun Feb 23, 2014 7:12 pm
once you have removed those bolts, you need to knock it up-wards to unhook the seat from the upper retaining clips.
Durango2k
Post by Durango2k » Sun Feb 23, 2014 9:04 pm
And be careful not to rip the side cushions, the edges of the hinges are Sharp.
Carsten
Roger's E Type
Post by Roger's E Type » Tue Sep 09, 2014 12:01 am
Thanks for the replies - all the information I needed!
Cheers, Roger
Roger's E Type
Post by Roger's E Type » Tue Sep 09, 2014 12:06 am
Cheers, Roger
