#1 Upper Front Wishbone Replacement
Posted: Fri Sep 26, 2014 12:01 pm
Hi All,
This is for a Series1 1967 4.2.
The top L/H ball joint has failed on the MOT for the second time in 3 years and I have decided to replace the complete wishbone with the type that has the one piece ball joint. These seem available from CMC or Barretts.
Firstly would it be best to replace both sides and secondly who has bought these from either supplier and can recommend which is the best one of the two.
The other problem is that I replaced the steering column bushes 2 years ago (they are the plastic type) and over time they seem to have expanded and are making the steering stiff. Can anybody recommend the best supplier for these and is it best to take a slight amount of material from the inside of the bush before fitting to give a little more play in the bush and column.
Thanks Phil
Thanks Phil
