#1 Motif bar
Posted: Wed Oct 08, 2014 3:29 pm
by andreblor
Hi All,
I am currently looking at purchasing a Series I roadster, finally!!!!! I have just one question, the motif bar is not in place, neither are the motif bar extensions, essentially the bumpers' chrome work stops at the over-riders, leaving the centre section at the oval air intake completely void of chrome. I have seen this on many cars, especially US imports, my question is this; is this standard???? Is it an easy fix, I guess it is!!!!!!
many thanks,
Posted: Wed Oct 08, 2014 4:36 pm
Certainly not standard although the motif bar was removed along with the over-riders from 9600 HP, the first Jaguar demonstrator, so it could reach the magic 150mph. However the The parts you are missing are the bumper extension assemblies x2 #BD19113, the motif bar #BD17700 and the motif #C16336 plus the various seals, clips washers and the two rubber mountings #BD24448. All available from SNGB.
Work out the total cost and get them to reduce the price of the car accordingly. Be aware that repro parts are not always a good fit so expect to fineness them or get the seller to do the whole thing for you as part of the deal.
Posted: Wed Oct 08, 2014 6:46 pm
by Durango2k
I got 2x no. 4 (the small edges) from Pete, and these parts have the problem that the threads are broken, and I had to drill Out some stud remains.
Now- after some thinking- I know What I will do to Repair them : i will Drill an 8 mm hole, and fit a "rounded" nut with the correct thread size in There, and Weld it in place.
The Other 2 damaged threads can be enlarged, because it's just a Screw and a Bolt through them. But the Former One has the rubber Blocks fitted, which can't take more then a little Force before the bonding breaks, so beware.
Finally, rechrome it is...
Carsten
P.s. I do have a tool which can rivet Nuts in pre-drilled holes, but metric threaded-Rivets only. I tried to re-cut these for UNF but failed, and re-Cutting the rubber thingies breaks the bonding destroying them.
Posted: Wed Oct 08, 2014 8:36 pm
by Simon P
Which reminds me, I caught a bit of the Italian Job again the other night, and neither 848CRY nor 619DXX ran with motif bars in the film.
Posted: Thu Oct 09, 2014 3:52 pm
by andreblor
Many thanks to all for the replies, much appreciated, now looking forward to my new purchase!!!!!
Saying goodbye to my 1972 BRG SIII roadster is tough, but once I see the SI, wow!!!!!!!!!!!!!
Alot of work ahead, and I will no doubt be annoying you all for years to come!!!!!
thanks all
J
