Where to apply paint; gold head?
64etype
#1 Where to apply paint; gold head?
Post by 64etype » Tue Dec 16, 2014 8:04 pm
I was looking at photos in the "FACTORY FIT - Series 1 3.8" sticky for guidance as to where to apply gold paint to the cylinder head and noted that the first series of photos (a late 3.8 red OTS) show the gold color in the "valley" ending at the cam cover flange. The second car in the string is a '63 white OTS, and it shows the gold paint ending at the horizontal plane of the head bolts. (In other words, the paint does not cover the elevated, near vertical areas between the head bolt surface and the cam covers). I much prefer the look of the later, but wonder if it's "factory fit"? Thanks.
Eric
jag68
Post by jag68 » Tue Dec 16, 2014 9:53 pm
It's a question that has come up without any satisfactory answer as far as I'm aware. I've always painted the complete head on the engines that I've done on the basis that I can't see Jaguar actually bothering to mask, in some way, the flat vertical machined area above the seats for the nuts - and for no purpose to boot. On some of the older heads I've seen that surface has occasionally had bits of paint on it - but that's not entirely reliable as to the practice as over the past 50 years somebody could and probably did repaint it.
1967 E Type coupe
1968 E Type OTS
2007 XKR
Post by abowie » Tue Dec 16, 2014 10:23 pm
Don't know if it's right but this is what we do.
No paint on the manifold faces either.
SEJohnson95
Post by SEJohnson95 » Wed Dec 17, 2014 8:07 am
This is how Richard painted his 3.8 head:
Once again no paint on the manifold faces. I kind of like that sacrificial set of old plugs in gold! :P
Simon Johnson
Simon P
Post by Simon P » Wed Dec 17, 2014 9:01 am
SEJohnson95 wrote:Once again no paint on the manifold faces.
Psssttt..... Top left in the first photo :wink:
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
SEJohnson95
Post by SEJohnson95 » Wed Dec 17, 2014 9:46 am
Yeah alright thanks Simon. I'm not very well ATM so probably not thinking straight! ;)
Simon Johnson
Simon P
Post by Simon P » Wed Dec 17, 2014 9:53 am
Nothing a bit of wire wool won't fix (the paint that is, not your cold... :wink: )
64etype
Post by 64etype » Wed Dec 17, 2014 3:05 pm
Thanks for the replies, but I'm still curious as to what is "factory fit" for those vertical strips between the plane of the head bolts and the cam cover flanges. One of the cars I identified in my original post (both listed as definitive, unrestored and original in the "FACTORY FIT - Series 1 3.8" sticky) is apparently "incorrect". If the head on the white car is "factory fit" and unmolested, then every other car in that string of examples is suspect. (I realize this is an obscure detail).
Eric
jag68
Post by jag68 » Wed Dec 17, 2014 7:07 pm
This is also obscure - but you should not paint the surface under the nuts that secure the head. This distorts the torque setting, and can lead to loosening of the nut as the paint moves away from the pressure. I've seen this failure in aircraft engines painted under the nuts that secure the jug to the block with very bad results.
1967 E Type coupe
1968 E Type OTS
2007 XKR
SEJohnson95
Post by SEJohnson95 » Wed Dec 17, 2014 11:10 pm
jag68 wrote:This is also obscure - but you should not paint the surface under the nuts that secure the head. This distorts the torque setting, and can lead to loosening of the nut as the paint moves away from the pressure. I've seen this failure in aircraft engines painted under the nuts that secure the jug to the block with very bad results.
The paint was removed from the threads afterwards, I saw it. Incidentally Richard has built and flown his own aircraft for five years (RV7) and held a license for a long time so I think he's got it covered. Thanks for the heads up though :)
Simon Johnson
64etype
Post by 64etype » Wed Dec 17, 2014 11:55 pm
I believe he's talking about the paint where the nut/washer seat against the head surface as opposed to threads.
Eric
SEJohnson95
Post by SEJohnson95 » Thu Dec 18, 2014 9:08 am
Yep, I suppose he is :) I'm just going to stop digging the hole now, somebody take the shovel off me? ;)
Simon Johnson
Post by Heuer » Fri Dec 19, 2014 3:44 pm
64etype wrote:Thanks for the replies, but I'm still curious as to what is "factory fit" for those vertical strips between the plane of the head bolts and the cam cover flanges. One of the cars I identified in my original post (both listed as definitive, unrestored and original in the "FACTORY FIT - Series 1 3.8" sticky) is apparently "incorrect". If the head on the white car is "factory fit" and unmolested, then every other car in that string of examples is suspect. (I realize this is an obscure detail).
I suggest you rely on the red OTS and blue FHC as I know their provenance.
64etype
Post by 64etype » Sat Dec 20, 2014 3:14 pm
Probably right, although the red car has some odd little inconsistencies as well...particularly on the right side in the vicinity of the fuel filter. As Angus noted there are screws attaching the data plate, and I noted red paint on the data plate...also red paint on the bolts that attach the front frame to the firewall on that side...plain black oxide (slightly corroded) hardware everywhere else on the frame, which I believe is correct.
Eric
Post by Heuer » Sat Dec 20, 2014 4:02 pm
The car belongs to a friend of Bob Stevenson and Bob reckons it is untouched. The US importer was fond of touching up the paintwork after the cars landed because rust formed quickly in the salty air of the ship.
