- Administrator
Post
by Heuer » Thu Jan 01, 2015 3:12 pm
I have been corresponding with Maikel
http://etypetools.co.uk/ over various subjects including the tool kit. I have always been perplexed by the inclusion of an 'L' shaped screwdriver in many tool-rolls and I assumed they were either owner additions or put in there by the Factory to fill a gap left by the redundant brake adjuster Allen key. Maikel mentioned that he thought it was nothing to do with the E-Type and was part #C10154 for the battery terminals on XK cars. His comment made me think back to the hassle I had fitting the battery in my FHC (I am convinced they built the car around the battery :D ) because the right hand helmet connector is held in place by a slotted screw and the heater box restricts access. Only way I could secure it was using a (modern) L shaped screwdriver - never occurred to me to use the one in my tool-roll
So was #C10154 added to the toolkit to allay customer concerns about battery removal?
Thoughts anyone?
Post
by PeterCrespin » Thu Jan 01, 2015 5:56 pm
If you opt for inboard terminals as Jag did you are duty-bound to offer a fastening tool if you also use cap terminals. Even clamp-type are iffy under there and I don't recall them emphasising STRONGLY that the live terminal must be attached before the ground one to avoid expensive/dangerous/painful fireworks from accidental tool-to-body or heater contact. I always get nervous dropping a battery into a 6-cyl E-type with inboard terminals. I get nervous offering the rectangular clamp up, even with rubber bits, as these drop away easily and it only takes a very few millimetres of poor positioning to bridge both thermal posts - yikes!
Post
by christopher storey » Fri Jan 02, 2015 10:42 am
Indeed, Peter . On mine I have decided B*&^ger authenticity and use batteries with outboard terminals . Even then I have to pull the heater upwards to get modern batteries into place
paydase
Post
by paydase » Fri Jan 02, 2015 5:32 pm
christopher storey wrote:Indeed, Peter . On mine I have decided B*&^ger authenticity and use batteries with outboard terminals . Even then I have to pull the heater upwards to get modern batteries into place
Christopher, on my car, with inboard terminals and a standard modern battery, no need to pull the heater upwards.
Once the terminals and the strap are off the battery can be easily tilted and pulled for removal.
Serge
1964 (3.8) FHC
1961 OTS
