#1 Bonnet removal
Posted: Fri Jan 30, 2015 8:53 am
1966 Series 1 2+2 4.2 4sp
Hi all,
I apologise if this topic has been covered before. I have searched through forum topics and found posts that refer to the fact that there are posts covering it - but have not been able to find the actual posts.
At some point soon I want to remove the bonnet from my Series 1. Various workshop manuals suggest removing it by unbolting the adjusting blocks on the bonnet itself - with warnings as to the difficulty of re-aligning when fitting again.
However, it looks to me that it could be removed (with some man power to assist) by just by unbolting the two bolts the act as the bonnet pivot point on the subframe. Presumably therefore avoiding the re - alignment issue.
I understand that the bonnet is heavy. The idea being to tilt it forward, prior to removing the bolts, onto a thin mattress and rope it loosely to the garage wall.
Remove the bolts and use the "help" to manoeuvre the bonnet for storage.
What am I missing?
Cheers, Roger
Hi all,
What am I missing?
Cheers, Roger
