Does anyone make parts to add seatbelts to a '61 OTS
adfergusson
#1 Does anyone make parts to add seatbelts to a '61 OTS
Post by adfergusson » Wed Sep 17, 2008 10:29 pm
I know, I'm a sissy!
But I think that adding seatbelts to my car would improve safety without detracting from the nature of the car. I know latter S1s have seatbelts but I don't think that my '61 OTS has the strengthened mounting points to attach seatbelts to. But once again I'm not really sure about this. Does anyone make the components to add a seatbelt to a pre-seatbelt e-type? Will I need to have hardened mounting points bolted in? Anyone got any ideas or advice (apart from to grow a pair and not to bother with the seatbelts!)
1961 3.8 flat floor OTS
harryetype
Post by harryetype » Thu Sep 18, 2008 5:40 am
Quickfit who advertise in the back of the club mag make seat belts to original factory spec which look great. they will also fit them correctly and strengthen the mounting points.
Their not cheap, but they are the best and after all if you are going to fit seats for safety they need to work.
Harry
My Dads old V12 TOM 32
1968 Roadster
Post by Heuer » Thu Sep 18, 2008 10:26 am
I have Quickfit seatbelts and the company are a delight to work with. They even offered to put cast leapers on the seat belt buckles (same leaper as on the 3.8 ashtray actually) which is a nice touch.
adfergusson
Post by adfergusson » Fri Sep 19, 2008 11:13 am
Great! I'm not planning on crashing her, but I 'd like to know that I might live if I do. And yes, I've started referring to my car as 'her'! Its love!
Dave K
Post by Dave K » Fri Mar 06, 2009 7:36 pm
harryetype wrote:Quickfit who advertise in the back of the club mag make seat belts to original factory spec which look great. they will also fit them correctly and strengthen the mounting points.
There not cheap, but they are the best and after all if you are going to fit seats for safety they need to work.
Just joined this site and saw a couple of posts relating to seat belts and Quickfit SBS. I found them hopeless to be honest they had my hardware for 6 weeks did nothing and then said they never even received them. I spoke to different people everytime some who could hardly speak English so I had them returned and sent them to FDTS ltd in Byfleet who were execellent and supplied the correct webbing. I supplied all the hardware and it cost ?65+ VAT to have them made in Grey. Very quick delivery as well.
Friends who have used them also said they were pleased with their work.
My car is also a '61 and didn't have the supports fitted for the shoulder harnesses however I took the measurements from a later car and made my own. If anyone wants the drawings please let me know and I'll send them.
Post by Heuer » Sat Mar 07, 2009 12:57 pm
Thanks for the info - I will add FDTS Ltd to the Recommended Specialist list.
1954Etype
Post by 1954Etype » Sat Mar 07, 2009 4:30 pm
Second that regarding FDTS - they even provided FOC a couple of buckles that were missing.
daverawle
Post by daverawle » Fri Mar 13, 2009 10:45 am
My S1 is fairly early, '63 and has the seatbelt mounts but the upper fixing point is fairly low down. Problem with this is in the event of a crash the belt will pull the occupant down as well as restricting forward movement - this compresses the spine - not good! If adding fixing points I would copy those from a later car which I think were higher.
1963 OTS
