Clutch Slave Cylinder Bleed Screw Position
neil4444
#1 Clutch Slave Cylinder Bleed Screw Position
Post by neil4444 » Fri May 08, 2015 11:27 am
Should the bleed screw be installed on top of the clutch slave or beneath as I've seen photos of both ?
For access purposes I'd prefer it on the bottom. However I'm sort of assuming it should it go on top in order to enable elimination of air when bleeding ?
Neil
1962 S1 OTS
1967 S1 FHC
Post by Gfhug » Fri May 08, 2015 11:52 am
Neil, mine is at the bottom, but as you say photos will show either position.
For bleeding the clutch (or brakes) will you be using these?
http://www.demon-tweeks.co.uk/motorspor ... ed-bleeder
I'm sure you'll have read this before, but it should help with bleeding the clutch as well as the brakes:
viewtopic.php?t=6273
neil4444
Post by neil4444 » Fri May 08, 2015 11:59 am
Many thanks Geoff. I rather hoped I could put it at he bottom to make access easier. I wasn't aware of the speed bleeders but had read a few of the threads re bleeding & have invested in a Mityvac.
Cheers !
Neil
1962 S1 OTS
1967 S1 FHC
Red Kite
Post by Red Kite » Fri May 08, 2015 3:51 pm
Mine is at the bottom (S2) and it leaves a little air in the line. I find a good few actuations or an afternoon drive allows it to self bleed the last bits out.
Gerry.
S2 FHC 1R20003
neil4444
Post by neil4444 » Fri May 08, 2015 5:10 pm
Thanks Gerry, good to know. That settles it then !
Neil
1962 S1 OTS
1967 S1 FHC
