Early 4.2 FHC Outer Seat Belt Anchor Hole Position
Glyn
#1 Early 4.2 FHC Outer Seat Belt Anchor Hole Position
Post by Glyn » Tue Jun 16, 2020 6:02 pm
Apologies if this issue has been previously discussed but having searched the forum I can't find specific details of the positioning of the untapped (non transmission tunnel) seat belt anchorage. I am fitting 3 point static belts to my 65 FHC which assumedly at some stage (early 90s restoration pre my ownership) has had new floor pans fitted. The passenger side has a hole drilled in line with the seat slider rear screw anchorage right on the edge of the floor pan (exiting underneath through the bottom of the sill). The driver's side has no hole at all. I would have thought that the untapped anchorage holes should be in line with the tapped anchorage on the transmission tunnel and not in line with the further forward seat slider anchorage. Apart from anything else in line with the rear seat anchorage means the seat belt anchorage will be very squeezed between the seat and inner wall of the sill. Prior to my drilling / turning my floor pans into swiss cheese I would be most grateful if anybody could let me know where the holes are supposed to be specifically.
Thanks.
Glyn
1965 S1 FHC OGS
1971 Lotus Elan Sprint FHC
1985 Glenfrome 6x6 Range Rover
PaulColeman
#2 Re: Early 4.2 FHC Outer Seat Belt Anchor Hole Position
Post by PaulColeman » Sat Aug 08, 2020 12:47 pm
If you still don't have an answer to this let me know as I have a 65 FHC bare shell with new Robey floors in it.
1965 Series 1 FHC
1976 Lotus Esprit
