Access to bonnet side of 8 pin multi socket/plug?
thegfb
#1 Access to bonnet side of 8 pin multi socket/plug?
Post by thegfb » Tue Mar 17, 2015 11:42 pm
Is it possible to access the 8 pin multi socket on the n/s bonnet diaphragm without removing the diaphragm?
Can it be reached from the n/s headlamp opening if the sugar scoop is removed?
Gareth
Dec '61 FHC originally LHD now RHD.
Post by PeterCrespin » Wed Mar 18, 2015 1:01 am
Yes.
thegfb
Post by thegfb » Thu Mar 19, 2015 12:32 pm
Thanks Peter.
Novice's question I know but I didn't want to get into removing the scoop without knowing it was going to get me to my suspect multi pin socket!
My failed main beam issue looks like it's resolved - no 2 pin had a poor intermittant connection so I re-did it and main beam works. whether it still will after I've re-assembled things remains to be seen!
Gareth
