Dashtop repair
CHASLON
#1 Dashtop repair
Post by CHASLON » Wed Mar 25, 2015 12:01 pm
I am replacing the cracked and damaged vinyl/foam dashtop (1965 S1 OTS) with a remade vinyl/foam part from SNG Barratt.
Having stripped the foam from the steel dashtop panel, I find that the 5 plastic demister ducts seem to have been moulded in place!
The ducts must have been inserted into their slots from underneath, before having a flange "formed" on the top to be clamped in place by the slim exit grills on top of the finished covered dash.
My questions are:-
Can the 5 ducts be removed and reused ? if so how?
Are replacement ducts available?
Do the original ducts have to stay in place whilst fiting the replacement vinyl/foam top?
I hope someone knows of a way round this problem.
chrisvine
Post by chrisvine » Wed Mar 25, 2015 1:12 pm
The ducts should be flexible enough so they can carefully be eased out of their slots in the metal dash and re-fit them prior to bonding the new vinyl top.
1969 S2 OTS, Elise S1
Candellara
Post by Candellara » Mon Mar 30, 2015 4:36 pm
I sent my complete dash top to BAS for re-trimming.
It wasn't expensive & came back perfect & ready to refit
69 4.2 FHC ex Race Car
F-Type V8S
Mercedes 300SL 107
Thim
Norway
#4 Re:
Post by Thim » Tue Jul 13, 2021 10:30 am
chrisvine wrote: ↑
may i ask how much it cost you?
Jaguar E-type s1, 1967 2+2. Under restoration by myself, slowly seeing the light at the end of the tunnel 👍
