location of fuses on the central board
Polse7317
#1 location of fuses on the central board
Post by Polse7317 » Mon May 18, 2015 12:48 pm
Is there anybody who can help me to fit the right fuse on the right place for my 63 XKE following the number of the following photo ?
neil4444
Post by neil4444 » Mon May 18, 2015 12:54 pm
Neil
1962 S1 OTS
1967 S1 FHC
Polse7317
Post by Polse7317 » Mon May 18, 2015 1:49 pm
It's obvious :oops:
neil4444
Post by neil4444 » Mon May 18, 2015 2:11 pm
By the way, I'm sure you're aware, but just in case...
...the fuse ratings on the plate are given in 'old money' blow rating i.e. the maximum current carried before the fuse blows. Modern fuses give the continuous rating which is usually about half the blow rating. So in position 1 you want a 17A fuse (= 35A blow rating), eg.
http://www.rimmerbros.co.uk/Item--i-GFS3035
More on the subject here...
viewtopic.php?t=3102&highlight=fuse+blow+rating
Neil
1962 S1 OTS
1967 S1 FHC
Polse7317
Post by Polse7317 » Mon May 18, 2015 3:09 pm
Thank's a lot Neil
