#1 Replacing rear brake cylinders & pistons
Posted: Thu Jun 04, 2015 10:48 am
Recently introduced myself and sure enough I have my first question about this 1966 S1 I am getting back on the road
Rear brakes are seized up, though back end otherwise looks good so I want to avoid dropping the rear suspension.
Have been able to access all 4 bolts on each of the four cylinders in order to remove. The problem though is removing the brake lines and inspite of copious Plusgas and heating, still no joy. So getting to the point where I'm thinking of cutting the pipes. i see that it is possible to buy a new set of copper pipes for under ?100. Has anyone fitted these?
Also my plan is to fit exchange reconditioned pistons and callipers as done by Moss. Again any views on these bearing in mind intention is to keep car in standard unrestored condition?
