#1 Centre console removal (one more...)
Posted: Sun Jun 21, 2015 9:23 am
I have looked into the relevant threads but I couldn't succed in removing my centre console using the tips given.
So I first removed the centre arm rest and the gear gaiter, then engaged the rear gear (also tried 4th gear) and pulled the hand brake to clear up the way as much as possible ... to no avail, even by twisting the console sideways!
I understand that the trick is tthen to release the handbrake cable from the lever but I don't see on which nut to act to do it certainly and simply.
Thanks for giving indications.
