#1 Engine does not start (fixed...for now)
Posted: Sun Jun 21, 2015 7:19 pm
I have had ignition/carburation problems since some time, in particular when engine revs above 3000 rpm at full throttle, with occasional apparent fuel starvation and detonations.
Bizzarely, the issue does not appear on every run and it turns out that sometimes the engine responds nicely up to 5000 rpm.
Today, when I cranked the engine (using full choke) it painfully started on second attempt then collapsed. More attempts with or without choke did not succeed.
I then noticed that I had not heard the usual ticking of the fuel pump when turning the key for ignition.
I verified that the 5 amps fuse for the fuel pump is not grilled.
What puzzles me is that the fuel filter bowl however remains full of gas and I am wondering how cranking the engine would not empty it because of the carbs maybe sucking the fuel. But maybe I'm wrong, the pump should push the fuel and without it, no fuel move...
I suspect therefore a dying fuel pump (it seems to be an original submersible Lucas pump, positive earth) but am not sure...
Do you think that could be the culprit?
I have one spare fuel pump.
I imagine that the first check to do would be to measure voltage across the wires in the boot to verify that the pump is correctly powered.
To do so, how should I proceed to remove/open the small block covering the electical wires (is it cliped)?
Then, if voltage is there and if the pump does not work, how to proceed to remove the pump and make the change safely?
Obviously I should first disconnect the battery.
Then I should probably empty sufficiently the fuel tank (right now it's full and I fear that if I remove the flange on the tank, fuel will flow out). Is it possible to suck up some fuel through the reservoir cap or should I empty the tank through the drain plug (difficult if seized)?
Any other useful advices (verify that the pump does not touch the bottom of the tank, specific care on mounting, orientation, etc. change the seal or not...)?
Help appreciated, please indulge my questions, it's my first mechanical repair on this car...
