Clutch issue upon release in 67 E-Type
Jagxkeots
#1 Clutch issue upon release in 67 E-Type
Post by Jagxkeots » Tue Jul 14, 2015 2:23 pm
Any idea what can cause a delay of clutch engagement after release of clutch pedal?
During push of pedal the gears shift, no grinding but when I remove my foot it takes a few seconds to engage.
New clutch master, rubber hose, fluid and slave.
Jack
1967 OTS
Mark Gordon
Post by Mark Gordon » Tue Jul 14, 2015 4:23 pm
Is there a pinching or a kink in the rubber hose?
Post by Heuer » Tue Jul 14, 2015 4:25 pm
Which slave are you using - the short 80mm one or the longer hydrostatic one? The former requires a return spring but if you fit it to the latter you will have all sorts of problems.
