Exhaust camshaft removal
PhilipM
#1 Exhaust camshaft removal
Post by PhilipM » Mon Aug 31, 2015 12:01 pm
Hello
Apologies if these are stupid questions, but since after looking at both the Haynes manual and reading posts on here I have not totally understood the assembly of cam chain, tensioners and camshafts, I would rather check.
Is it possible to remove just the exhaust camshaft without touching the pinions on the inlet camshaft?
The tensioner only moves a small amount clockwise. Does it require some effort to turn further?
Once both bolts holding the pinions are removed how are the pinions moved forward off the camshaft end?
Philip
Philip
Post by mgcjag » Mon Aug 31, 2015 1:23 pm
Hi Philip....If you look in the knowledge base section of the forum you will find the maintenance manuals....There is a section on camshafts starting at page B.32...... engine must be at tdc to start with both cam keyways at 90deg to the cam cover face (pointing up)
Yes just one can can be removed...Once bolts are removed sprocket assembly it can be taped or pulled off....re tensioner see page B63 you need to press in the locking plunger to turn the adjuster.....hope this helps Steve
Post by christopher storey » Mon Aug 31, 2015 5:40 pm
Also, before attempting to move the tensioner you must slacken the locknut . This is a 1/2 inch Whitworth size so you may need to adapt a spanner or if the worst comes to the worst, use an adjustable !
Post by abowie » Mon Aug 31, 2015 10:52 pm
christopher storey wrote:Also, before attempting to move the tensioner you must slacken the locknut . This is a 1/2 inch Whitworth size so you may need to adapt a spanner or if the worst comes to the worst, use an adjustable !
And don't drop it down the hole... you don't actually need to remove it, just loosen it off enough to be able to rotate the adjuster.
I usually stuff some rags under the timing sprocket as well to mimimise the risk of dropping a bolt or bits of lockwire down there.
PhilipM
#5
Post by PhilipM » Tue Sep 01, 2015 7:53 am
Steve/Andrew
Thanks for your replies and I'll have a look at the pages as suggested.
Your comments confirm what I had deduced from further reading. One further question; I am pushing the little plunger in and the serrated plate then moves quite freely but perhaps only through 20 deg. Is this it since during this movement it doesn't appear to do anything!
Philip
Philip
Post by mgcjag » Tue Sep 01, 2015 8:19 am
Hi Philip....If you have loosened the nut an d hold in the plunger....then use the tool or long nose pliers in the two holes to loosen or tighten can't remember how far it moves but you should notice the chain loosen or tighten...Steve
