PEDLE BOX LH RH
#1 PEDLE BOX LH RH
IS THERE A DIFFERENCE BEETWEEN LH OR RH DRIVE PEDLE BOX,WILL ONE FIT THE OTHER SIDE
DEPENDS ON THE CAR!!!
THE ONE YOU WANT FITS ON BOTH SIDES!~!!!
BUT THE ACCELERATOR PEDAL HOUSING DOESN'T!!!!!!!!!
#3 Re: PEDLE BOX LH RH
The pedal box assemblies can have 'the same' mounting points for each side and still not fit both sides due to pedal angles/bends.frenchi wrote:IS THERE A DIFFERENCE BEETWEEN LH OR RH DRIVE PEDLE BOX,WILL ONE FIT THE OTHER SIDE
