#1 What is this?
Posted: Thu Sep 17, 2015 6:37 pm
by Pim
Can anyone tell me what this is?
I was checking how to remove the pipes behind the bulkhead and there it was, some kind of cable with a spring and a fixture. Seems to come out thenother side of the bulkhead in the engine compartment.
Posted: Thu Sep 17, 2015 7:16 pm
by Alty Ian
Its the wiper parking position adjuster. It connects to the wiper rack.
Coincidentally, I just adjusted mine when getting the wipers going, I needed to use it to get the wiper parking switch to work correctly. Check your wiper rack and you will see where it connects.
Posted: Thu Sep 17, 2015 8:27 pm
by Pim
Thanks Ian, I will have a second look at it. See if I get it.
Posted: Sat Sep 19, 2015 12:02 am
by PeterCrespin
It's a courtesy light switch from where I'm looking. It IS only a small iPhone screen though...
Posted: Sat Sep 19, 2015 3:37 am
by Moeregaard
Parking adjuster for the windscreen wipers. The small knurled knob at the other end of the cable protrudes from the firewall on the left side.
Posted: Sat Sep 19, 2015 10:16 am
by PeterCrespin
Ah, right, the inboard wiper rack end. I was looking for the knurled knob - duh.
Posted: Sat Sep 19, 2015 8:30 pm
by Pim
Moeregaard wrote:Parking adjuster for the windscreen wipers. The small knurled knob at the other end of the cable protrudes from the firewall on the left side.
That is indeed where it goes, with a kind of flat hex nut on the outside of the bulkhead.
Posted: Sun Sep 20, 2015 7:45 am
by Polse7317
That's it :
#9
Posted: Mon Oct 19, 2015 5:23 pm
by Pim
Thanks, looks different than mine. PO painted over it.
#10
Posted: Mon Oct 19, 2015 6:12 pm
by vee eight
Out of interest, how do you adjust the position.
Is it from the knob on the bulkhead or from the cable inside the dashboard.
Posted: Mon Oct 19, 2015 6:34 pm
by Alty Ian
vee eight wrote:Out of interest, how do you adjust the position.
By turning the knurled knob you move the arms relative to one another and compress or decompress the spring over the thread which keeps it under tension.
#12
Posted: Tue Oct 20, 2015 9:18 am
by Pim
By turning the knurled knob (located on the bulkhead, right side of the picture - PvdS) you move the arms relative to one another and compress or decompress the spring over the thread (in the dashboard, left side of the picture - PvdS) which keeps it under tension.
