garrycol wrote:
So before posting I checked my own Scientific 4.2 manual and the statement is exactly the same. Hence my and the owners confusion.
As far as the wiring diagrams go - also checked them - as far as the clock goes checked them as well - both a positive and a negative supply and no other information - the 3.8 has the clock as a rectangular box and the 4.2 as a circle as the clock - otherwise the wiring of the clock in the diagrams is the same.
So I take it from your comments that that the clock is to be connected as it should be - positive to the clock and negative to the earth.
Still some mix up I fear.
1) The main manual was written for the original 3.8 version of the car, which was positive earth (negative clock feed) and used serial numbers without prefix, in the 85xxxx to 88xxxx range as shown in your photo from the 3.8 section of the manual.
When the 4.2 came out there was supplement and again for Series 2 etc. These are today bound into the same book but constitute different manuals. So you obviously need to look in the 4.2 part for 4.2 info. There's no such thing as a 4.2 (all negative earth) with a 3.8 VIN of the sort shown in your photo, hence the positive earth clock info in the photo is in the 3.8 section, applies only to 3.8 cars using those VINs and cannot apply to 4.2 cars.
Nor does the positive earth wiring diagram shown in the 3.8 section - which is the only one showing positive earth clock feed - apply to a 4.2.
If you use the wiring info in the 4.2 section it is referenced for the correct 4.2 type VIN 1Exxxxx (no confusion) and is also negative earth (no confusion) and therefore matches your friends dash clock markings (no confusion). Ergo, any confusion is because you're looking in the wrong place and using 3.8 info on a 4.2 car.
