#1 heater return pipe
Posted: Fri Oct 23, 2015 1:42 pm
by Wicker
With respect to a 1965 E-Type FHC
At the risk of appearing over nit picky could someone advise the proper mounting of this pipe on the right hand side of the engine block. Should the brackets be attached to specific manifold studs?
Many thanks
Posted: Fri Oct 23, 2015 9:45 pm
You'll find that they will only fit properly on the correct studs.
The longer bracket goes on the second stud from the front, the short bracket on the third from the rear.
Posted: Mon Oct 26, 2015 1:41 pm
by Wicker
Perfect, Andrew
Thank you
