PaulColeman
Post
by PaulColeman » Tue Dec 22, 2015 8:17 pm
Does anybody have a scrap bulkhead - the rougher the better. I need a section to repair my butchered bulkhead. I don't believe anybody makes this particular section and I don't fancy trying to fabricate it.
This is the part I need...
Thanks, Paul.
1965 Series 1 FHC
1976 Lotus Esprit
Post
by abowie » Tue Dec 22, 2015 8:56 pm
That's all covered by trim so any repair doesn't need to be perfect.
PaulColeman
Post
by PaulColeman » Tue Dec 22, 2015 9:03 pm
Yes that's true and if the worst comes to the worst I'll just cut a plate with a hole in it out of 1.6mm steel and weld it in but it would be nice to find a proper replacement panel - long shot I know, but if you don't ask you don't get.
What gets me is the fact that the previous owner butchered this to try and fit an electric aerial. Obviously it's a structural part of the car and he's butchered it to fit a frigging aerial.... noooooooo you moron.
1965 Series 1 FHC
1976 Lotus Esprit
neil4444
Post
by neil4444 » Tue Dec 22, 2015 9:40 pm
Easy job to make a plate & probably quicker than sourcing a bulkhead. Plus you've got the other side to mirror a template from. The only reason you might want to be fairly accurate is if you want to install speakers there.
Neil
1962 S1 OTS
1967 S1 FHC
neil4444
Post
by neil4444 » Tue Dec 22, 2015 9:42 pm
Also notice the brace across the doorway Paul, is the roof off ???
Neil
1962 S1 OTS
1967 S1 FHC
Post
by christopher storey » Wed Dec 23, 2015 10:44 am
Hutsons make complete bulkheads, and so they almost certainly can produce that pressing for you. Ask Andy on 01274 669052
paulsco
Post
by paulsco » Wed Dec 23, 2015 12:26 pm
Hi Paul,
Relatively easy to fabricate, but if you don?t fancy it
www.Monocoque-metalworks.com
Will make any part you need.
PaulColeman
Post
by PaulColeman » Wed Dec 23, 2015 1:20 pm
paulsco wrote:Hi Paul,
Oh no he won't
I did try him first.
Hutsons sell the entire part at about ?250 so I'll have a go at making one first - should be fun :?
1965 Series 1 FHC
1976 Lotus Esprit
