#1 hatch trimming problem
Posted: Sat Dec 26, 2015 12:02 pm
by Polse7317
I am on the hatch trimming and I don't know how to fit the PVC "seal" around the hatch metal aperture. Must I stick it on the metal with the "return" pvc lip beetween the rubber seal and the metal edge ?
Posted: Tue Dec 29, 2015 2:16 pm
by Spark
I could also do with the same help please
I believe they are pop riveted on to the surround but then some are also glued?
Posted: Tue Dec 29, 2015 3:49 pm
by paulsco
I stripped mine off at the start of my restoration and they were fitted as in Lataud's picture.
I did not remove rivets, so I assume they were glued.
The inner trim panels sit on top of them.
Posted: Tue Dec 29, 2015 5:46 pm
by Polse7317
I need a very strong glue to stick it at the right place and some good press to keep it there !
Posted: Wed Dec 30, 2015 3:27 pm
by paulsco
I think the trim panel will keep it in place.
Posted: Wed Dec 30, 2015 4:10 pm
by 1954Etype
Warm it up with a hair drier and then glue a little bit at a time.
Posted: Wed Dec 30, 2015 7:09 pm
by Polse7317
Angus you are right, I must take my time and stick it step by step.
#8 slowly does it
Posted: Thu Dec 31, 2015 1:51 am
by johnj
Hi I have just done mine, its a task but take it slowly, fit it before aperture seal & inner panel trims its just glued with good quality adhesive ,glue both the body and trim, warm trim with heat gun as you go, a little at a time and mould it into place , then fit interior side trims etc and rubber apperture.
best of luck
Posted: Thu Dec 31, 2015 8:35 am
by Polse7317
Thanks I' ll do that
#10
Posted: Sat Jan 02, 2016 12:11 pm
by Polse7317
I began yesterday with e few inches :
and this morning, it's fine , so I continue.....
#11 rear seal
Posted: Thu Jan 07, 2016 5:09 pm
by 154WHU
sorry to ask ,but were did you get the seal as I was told they are not avaliable any more.
Regards Clive
