Am i missing some part of the lock ?
1 : key
2 casing for the lock + new lock
3 washer with two internal tabs
4"piston" wich must turn on itself in some location when i turn the key
5 spring
6 case holding the operating lever
7 operating lever
8 adjustable screw with its bolt
I think i must have a problem with the part 4 which seeems to be disconnected sometimes when i turn the key .
May be this part is worned at its end.
PS: What is the use of the little round hole in the part 7 ( location of a kind of pin ?)
Any advice is welcome
