Hi all,
When I was under the car draining the radiator (see my previous post here re. header tank replacement) , I found that the drain tap actually was no tap but a bolt whereas the parts manual lists/shows a "tap". I was just wondering. Can anyone enlighten me if, for a 1966 series 1, 4.2 (not 2+2) this is "original" or should this be a genuine "tap", i.e. like the one you have on the side of the engine block ?
Many thx for any feedback
cheers
Erik
Radiator drain tap: series 1, 4.2 FHC 1966
Erikantwerp
Topic author - Posts: 360
#2
Erik
I think the early cars (3.8's) had the tap, later cars have the bolt.
Erik, I have also a 1966 series 1, 4.2 FHC and there is a tap, the same as on the side of the engine block.
Chris
Chris
Erikantwerp
#4
David,
Chris,
many thx for your replies but...the mistery continues... :)
cheers
Erik
Chris,
cheers
Erik
Erik
As far as I can see from the various parts books all S1/2 cars should be fitted with a radiator drain tap (3.8 = C2354, 4.2 = C25126, S2 has a different tap again) and they are readily available from the usual suppliers. My car has a Cambridge Motorsports alloy radiator with a bolt instead of a tap, presumably the preferred option for racing. So another thing to add to you 'to do' list - you just need to think if you can do it without draining the system again :?
Moeregaard
#6
Both of my Series One E-Types have/had taps. I replace these with a pipe plug that has its head drilled for safety wire, and wire in in place. This way I never have to give it a second thought until it's time for a coolant change. I believe the factory tuning manual suggests doing this with both the radiator and block drains.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
Erikantwerp
#7
David,
many thx for your helpful replies. I guess I will stick for now with my "bolt" for the same reasons Mark mentioned.
cheers
Erik
cheers
Erik
