Fixed Head wrote:
As for Springer's original question, the angled chrome strip on the upper front edge of the panel was NOT present, nor was the upholstered piece just behind it, for the first part of 3.8 production. There was also a change in the design of the main upper chrome strip. These changed around the time that the armrests were added to the doors, mid to late 63 production I think, though maybe not all at exactly the same time.
I believe you can find chassis numbers recorded for at least some of these changes using the usual published sources, and the parts books.
Right. The upper forward/angled chrome first shows up in the parts manual for the 4.2 S1. The part number for the upper/rear chrome also changes for the S1 4.2. The suppliers lists are the same. As I mentioned previously, the 3.8 cars depicted in the "Factory Fit" section of this forum, do not depict the angled chrome.
Haddock states that armrests were added in about June 1963, and door trim was changed in about August 1964. I noted that blue FHC in the "Factory Fit" section, an 887XXX s/n, does not have either the chrome or the upholstered wedge at the forward/top of the door. My 889XXX car has the upholstered piece, but not the angled chrome. So changes were occurring right in that time frame.
