#1 brake servo repair kit needed
Posted: Wed Feb 10, 2016 2:33 pm
by frenchi
hi my brake servo number is 3231 c22c and was looking for a repair kit hopfully just the rod rubbers as large rubber cup looks all ok,its for a 67 2x2 4.2
Posted: Wed Feb 10, 2016 3:29 pm
by PeterCrespin
Hmm. Tough one. Where have you tried?
http://lmgtfy.com/?q=1967+E-type+servo+kit#
BTW I also know some places that sell petrol and oil if you're stuck.
#3 hi
Posted: Wed Feb 10, 2016 3:44 pm
by frenchi
barratts robbys snc and a few on the net but nothing with the numbers on my servo that would match,whats the chance,this servo has been full off juice not dried up rubbers look ok but fluid is greasy black and quite a bit in the servo drum but clean fluid ,do you think a clean up and back in no pitting on sleave
Posted: Wed Feb 10, 2016 6:25 pm
by paulsco
Hi Frenchi
I think the number you quote is the Lockheed casting number; mine is 3231-
822C.
If you value your life you should at least re rubber the servo. If there is fluid in the drum it must have leaked past one of the seals, so I think this confirms it is leaking.
http://www.sngbarratt.com/ProductDetail ... b6a92d&l=7
Posted: Wed Feb 10, 2016 9:44 pm
I have rebuilt a few of the boosters and I'm pretty sure the kits are "one size fits all".
Buy one from SNGB or Manners etc.
Posted: Wed Feb 10, 2016 9:50 pm
by 1954Etype
Frenchi, not worth the hassle. Speak to Andy at Hutsons where they will exchange yours for a fully restored one with ssteel bore. Chances are yours is shot and you will only find out when you have rebuilt it, fitted and bled the system.
We never rebuild them.
Posted: Thu Feb 11, 2016 8:29 am
Fair comment. The only ones I rebuild are ones that have already been SS or brass sleeved in the past. The cast iron ones are universally stuffed.
Posted: Thu Feb 11, 2016 10:40 am
by paulsco
The genuine Lockheed slave cylinder body is available on special order from SNG for about ?120. (10894).
With a repair kit it is much cheaper than a reconditioned unit and if cast iron has lasted for the last 50 years it should outlast us.
http://www.sngbarratt.com/CatalogueProd ... 520&a=1175
#9 thanks fellers
Posted: Thu Feb 11, 2016 11:11 am
by frenchi
thanks to one and all managed to get the right repair kit new old stock with numbers matching ,,cooool
#10
Posted: Tue Mar 01, 2016 4:04 pm
by rossbraithwaite
1954Etype wrote:Frenchi, not worth the hassle. Speak to Andy at Hutsons where they will exchange yours for a fully restored one with ssteel bore. Chances are yours is shot and you will only find out when you have rebuilt it, fitted and bled the system.
I rebuilt mine with the refurb kit and it works perfectly well. Are you saying it is likely to start leaking fluid, presumably into the booster?
#11
Posted: Tue Mar 01, 2016 4:41 pm
by 1954Etype
No, you should be ok if it is the original bore and not pitted. If it is pitted and the seal wipes over that area, it could fail early.
#12
Posted: Tue Mar 01, 2016 5:05 pm
by rossbraithwaite
1954Etype wrote:No, you should be ok if it is the original bore and not pitted. If it is pitted and the seal wipes over that area, it could fail early.
OK, thanks Angus. It did not appear to be pitted. Fingers crossed!
