3.8 Lifting Point
neil4444
#1 3.8 Lifting Point
Post by neil4444 » Fri May 08, 2009 10:45 am
I'm in the process of disassembling my 62 3.8 OTS and am about to remove the engine. However there don't appear to be any lifting points or lifting straps. The service manual suggest that Jaguar used a special tool (Churchill engine lifting plate). Can anyone advise please ?
Many thanks,
Neil
Post by Heuer » Fri May 08, 2009 11:05 am
Neil
You should have two chromed lifting hoops between the cam covers.
The Jaguar tool is a load balancer and really not required providing you have an proper engine crane. e.g.: http://www.machinemart.co.uk/shop/categ ... ine-stands
neil4444
Post by neil4444 » Fri May 08, 2009 11:19 am
Hi David,
Thanks for photo. Unfortunately my car doesn't have those hoops fitted. Might nip down the breakers and see if I can find some.
Neil
daverawle
Post by daverawle » Fri May 08, 2009 11:32 am
Neil,
For what it's worth; the lifting brackets were fitted from Aug '64 on.
1963 OTS
neil4444
Post by neil4444 » Fri May 08, 2009 11:37 am
Do you know if they're also fitted on more recent vehicles such as the XJ ?
daverawle
Post by daverawle » Fri May 08, 2009 11:55 am
neil4444 wrote:Do you know if they're also fitted on more recent vehicles such as the XJ ?
Neil,
Martin Robey lists them:
C23607 ?12.14 ea
Ideally, you also need the matching/longer studs: C23609 ?5.20 ea
1963 OTS
neil4444
Post by neil4444 » Fri May 08, 2009 12:54 pm
Thanks David,
Have just ordered from Robeys.
