Fan Motor Relay Location
rojakilian
Topic author - Posts: 15
#1 Fan Motor Relay Location
i forgot to mention that the car is a 4.2 series 1.
Best regards
Robert
Best regards
Robert
#2 Re: Fan Motor Relais Location
Hi Robert...should be on a bracket bolted on top/front of the picture frame
#3 Re: Fan Motor Relais Location
Looking for a OTS 4.2 serie 1....!
and now have found a fhc xk 140
#4 Re: Fan Motor Relais Location
#5 Re: Fan Motor Relais Location
I cannot be 100% sure, but was the relay only on the 3.8 early cars? I may have that wrong but I recall when ordering my new wiring loom I was asked if it had the relay or not? Assuming it was not on later 3.8s did they delete it from 4.2s as well?
#6 Re: Fan Motor Relais Location
Fitted on 4.2 cars more info here http://www.myetype.co.uk/forum/viewtopi ... lay#p63724
#7 Re: Fan Motor Relais Location
that of course is a 4.2 series 2 with the twin fans I assume. Cannot see a reference to a fan relay in the series one 4.2 parts book though?
#8 Re: Fan Motor Relais Location
There is no fan relay on the Series One 4.2.
#9 Re: Fan Motor Relais Location
Hi Andrew....yes you are correct..there is no fan reley on the S1 4.2 diagram in the knowledge base
rojakilian
#10 Re: Fan Motor Relais Location
Hello again from Germany,
thanks a lot for your replies - i saw it now, there is, for what reason ever, no fan relay fitted in the ser.1 4.2. That is strange, because the 3.8 got one and the later series 1.5 and 2 got one again....the (new) loom i have is from a series 2 i guess ( i am puzzling a kind of "bitsa"car together from a mountain of new and used parts....) Its awful sometimes, even if it may now at least financially makes sense, i will never do it again...
Best regards
Robert
Best regards
Robert
#11 Re: Fan Motor Relay Location
It is a good idea to fit a relay.
