#1 Fan Motor Relay Location
Posted: Tue Jul 05, 2016 5:52 pm
by rojakilian
i forgot to mention that the car is a 4.2 series 1.
Best regards
Robert
#2 Re: Fan Motor Relais Location
Posted: Tue Jul 05, 2016 6:08 pm
Hi Robert...should be on a bracket bolted on top/front of the picture frame
#3 Re: Fan Motor Relais Location
Posted: Wed Jul 06, 2016 5:17 am
by Polse7317
I bolted it there :
#4 Re: Fan Motor Relais Location
Posted: Wed Jul 06, 2016 6:41 am
by Polse7317
Here is :
#5 Re: Fan Motor Relais Location
Posted: Wed Jul 06, 2016 9:05 am
by andrewh
I cannot be 100% sure, but was the relay only on the 3.8 early cars? I may have that wrong but I recall when ordering my new wiring loom I was asked if it had the relay or not? Assuming it was not on later 3.8s did they delete it from 4.2s as well?
#6 Re: Fan Motor Relais Location
Posted: Wed Jul 06, 2016 9:12 am
#7 Re: Fan Motor Relais Location
Posted: Wed Jul 06, 2016 12:06 pm
by andrewh
that of course is a 4.2 series 2 with the twin fans I assume. Cannot see a reference to a fan relay in the series one 4.2 parts book though?
#8 Re: Fan Motor Relais Location
Posted: Wed Jul 06, 2016 12:53 pm
by paulsco
There is no fan relay on the Series One 4.2.
#9 Re: Fan Motor Relais Location
Posted: Wed Jul 06, 2016 1:35 pm
Hi Andrew....yes you are correct..there is no fan reley on the S1 4.2 diagram in the knowledge base
#10 Re: Fan Motor Relais Location
Posted: Sat Jul 09, 2016 5:08 pm
by rojakilian
Hello again from Germany,
thanks a lot for your replies - i saw it now, there is, for what reason ever, no fan relay fitted in the ser.1 4.2. That is strange, because the 3.8 got one and the later series 1.5 and 2 got one again....the (new) loom i have is from a series 2 i guess ( i am puzzling a kind of "bitsa"car together from a mountain of new and used parts....) Its awful sometimes, even if it may now at least financially makes sense, i will never do it again...
Best regards
Robert
#11 Re: Fan Motor Relay Location
Posted: Mon Jul 18, 2016 8:57 pm
by 1954Etype
It is a good idea to fit a relay.
