Removing water temperature gauge
ETTony
#1 Removing water temperature gauge
Post by ETTony » Thu Jul 14, 2016 9:04 pm
Hi team,
Whilst waiting for my wiring harnesses to arrive i am moving the guages to the correct RHD layout.
Now I need to withdraw the Water Temp gauge, the wire is encased in a spiral steel wire sheath (similar to the choke or heater operating wires).
The wire and sheath appear to be permanently attached to the rear of the guage.
Similarly the sensor appears to be permanently fixed to the wire / sheath.
Do i pull the sensor back to the dash panel to achieve my goal.
Or perchance can they be disconnected.
Thanks. Tony
Tony in Devon
#2 Re: Removing water temperature gauge
Post by christopher storey » Thu Jul 14, 2016 9:36 pm
Tony : it sounds to me as though you have a non-standard bourdon tube type of gauge, ( similar to , but not identical to , that fitted to XKs and earlier saloons ) which is totally different from the electric gauge fitted as standard to all E types . The usual gauge is run by an electric wire taken from a sensor which is screwed into the top of the water passages of the manifolds/thermostat housings ( it varies according to model but for a 4.2 it is usually on the top of the inlet manifold at the front ) . perhaps if you posted a photo of your gauge and the pipe, someone may be able to help further
ETTony
#3 Re: Removing water temperature gauge
Post by ETTony » Fri Jul 15, 2016 11:03 am
Image[/url]
here are the components for my water temperature gauge.
i have not got rough with it yet.
thanks Tony
Tony in Devon
BRM
#4 Re: Removing water temperature gauge
Post by BRM » Fri Jul 15, 2016 1:17 pm
Tony,
Both of the gauges shown are non standard more modern replacements. Have all your gauges been been replaced with those ? Shame if they have.
That type of temp gauge contains a tube not a wire inside the sheath connecting the bulb to the gauge. It contains a liquid and the whole thing is a sealed unit. You will have to withdraw it all through the dash if you want to save it. The threaded bit on the back of the gauge looks odd though, almost like it should have a knurled nut on it like a speedo.
If you are as keen on originality as most people on here you will have to chuck them all away anyway and try to source a set of original gauges !
Brian
1969 S2 FHC 1R20267
1960 Austin Healey 3000
ETTony
#5 Re: Removing water temperature gauge
Post by ETTony » Fri Jul 15, 2016 2:36 pm
Thank Brian,
My fuel is Smiths and amps is a Lucas, so i guess they are proper.
The oil has a tube coming back to dash, Suntune again.
OK I need to find Smiths then, any hints where to look, or is Google my friend.
Thanks again
Tony
Tony in Devon
#6 Re: Removing water temperature gauge
Post by Heuer » Fri Jul 15, 2016 2:41 pm
Gauges come up fairly frequently on eBay.
ETTony
#7 Re: Removing water temperature gauge
Post by ETTony » Fri Jul 15, 2016 3:09 pm
Thanks David
Tony in Devon
#8 Re: Removing water temperature gauge
Post by Heuer » Fri Jul 15, 2016 3:26 pm
You can buy a new one http://www.smiths-instruments.co.uk/classic
Ideally you need to swap over the bezel from an original (wedge for S1, round for S2) but that can be easily done at any time:
ETTony
#9 Re: Removing water temperature gauge
Post by ETTony » Fri Jul 15, 2016 6:20 pm
Fantastic, men in a cave in Wales making Smiths classic gauges. Probably. :yellow:
Tony in Devon
