Crossmember trim
#1 Crossmember trim
I am in the middle of trimming the interior of my 62 fhc. I have been using a kit supllied by BAS and have so far been very impressed with the fit and quality of parts.
I am about to trim the crossmember that runs under both seats and through the transmission tunnel. BAS have supplied carpet material for this - I thought that the crossmember was trimmed in vinyl. I have had a look at the 3.8 factory thread and this confirms my thoughts.
Was this crossmember ever trimmed in carpet on later models??
Cheers.
Cheers.
62 3.8 FHC
91 Porsche 928GT
62 3.8 FHC
91 Porsche 928GT
#2 Re: Crossmember trim
Mine ( very early 4.2 ) certainly was , and indeed I cannot recall seeing one which did not have carpet. That does not mean , of course, that there weren't any but Jaguar generally always used carpet where it could be seen
#3 Re: Crossmember trim
Thanks Christopher. Carpet it is then.
Cheers.
Cheers.
62 3.8 FHC
91 Porsche 928GT
62 3.8 FHC
91 Porsche 928GT
#4 Re: Crossmember trim
My serie 1 is March 1963 and the cross member was in vinyl:
I have trimmed the same vinyl from BAS in blue :
Looking for a OTS 4.2 serie 1....!
and now have found a fhc xk 140
#5 Re: Crossmember trim
Hi Simon
Don't assume it was carpet....mine is/was vinyl....also March 63...
Jonathan
Jonathan
#6 Re: Crossmember trim
Thanks Lataud and Jonathan. I have plenty of red vinyl so I do have the chouce of finish. I would prefer to go with vinyl.
Cheers.
Cheers.
62 3.8 FHC
91 Porsche 928GT
62 3.8 FHC
91 Porsche 928GT
#7 Re: Crossmember trim
Carpet looks much nicer and is certainly much more durable
Moeregaard
#8 Re: Crossmember trim
My very early 4.2, #1E30036, had vinyl over the cross member, as did my later car, #1E32208. Both had unmolested interiors when I acquired them. I'd go with vinyl simply because it'll go around the corners better.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
#9 Re: Crossmember trim
Both my mid 62 cars are vinyl and were totally original . Carpet it incorrect for a 3.8 certainly of that age
And if that photo made you feel as ill I did, this is what she ended up looking like
#10 Re: Crossmember trim
Thanks for everyone's replies. If it was down to a vote, looks like vinyl would win!
Andrew, with a finish like that, it is a shame to cover it with anything
Cheers.
Cheers.
62 3.8 FHC
91 Porsche 928GT
62 3.8 FHC
91 Porsche 928GT
