fixation points for the throttle pedal ?
Polse7317
#1 fixation points for the throttle pedal ?
Post by Polse7317 » Sat Sep 10, 2016 11:11 am
I have 2 holes on the pedal to fix it on the floor . But i have only one "catched nut" in the floor i think there must be 2 nuts in the floor to fix the pedal , and if i am right, at what distance is the left hole ( lhd coupe) from the edge where the floor goes down to the foot "room" ?
Mich7920
#2 Re: fixation points for the throttle pedal ?
Post by Mich7920 » Sat Sep 10, 2016 4:47 pm
Hi Yves,
The throttle pedal is like a hinge. On the small part there is two holes.
Even if there is only one hole on your floor, screwing the one you have will give you the position of the other one.
I think you had changed this floor. Look at it under the car, you have two landmark for the screws.
One is hidden behind the left frame and the other is just next.
If it's a Martin Rebey, mine arrived without the holes, like this they can sold them for a left or right hand drive without doing this work.
Mich
Michel
Polse7317
#3 Re: fixation points for the throttle pedal ?
Post by Polse7317 » Sat Sep 10, 2016 5:24 pm
Yes Michel it's exactly what you say, it's a new floor.....I have forgotten that point :salute: so i'll make a hole on the left edge and bolt the pedal Under with a good seal !
Thank's
