Distributor
richard btype
#1 Distributor
Post by richard btype » Sat Oct 08, 2016 11:37 am
860403 starts and seemingly runs well but after recently experiencing a freshly restored car from CMC (truly amazing), particularly noticeable was how smooth and continuously the power was delivered throughout the rev range. Or should I say that in comparison 403 power starts to flatten to some degree from around 3k rpm.
The engine in my car is now 7,000 miles since being overhauled, (although that was in 1984) and have recently carefully shimmed the valve clearances and adjusted the timing chain tension. The carbs have been stripped, cleaned and rebuilt with a Burlen repair kit and new floats. The fuel filters are all clean, HT leads, plug caps, coil, points all new, and a full tank of shell 97 with octane booster, the exhaust system is all new mild steel with no leaks - the final part of this exercise is the distributor before I place it in the hands of some one who knows how best to tune the engine.
So I feel I should have this overhauled and the question is where might be the place to go? I don't want to go away from the original set up (i.e. electronic) for if the original design is working within its scope it is much easier to work to a known specification.
3.8 FHC Chassis no: 860403
DOM - 11th April 1962
Also
4.2 FHC Chassis no: 1E32173
DOM - 12th December 1965
1954Etype
#2 Re: Distributor
Post by 1954Etype » Sat Oct 08, 2016 12:59 pm
Distributor Doctor. We send all of ours there, put them in the car and they just work, every time.
Angus 67 FHC 1E33656
61 OTS 875047
richard btype
#3 Re: Distributor
Post by richard btype » Wed Oct 12, 2016 11:12 am
Thankyou Angus, Dizzy booked for early November!
Also
1954Etype
#4 Re: Distributor
Post by 1954Etype » Wed Oct 12, 2016 11:49 am
You won't regret it Richard.
61 OTS 875047
richard btype
#5 Re: Distributor
Post by richard btype » Wed Oct 12, 2016 12:47 pm
Tantalising Andrew! :bigrin:
Also
JagWaugh
Switzerland
#6 Re: Distributor
Post by JagWaugh » Wed Oct 12, 2016 1:50 pm
+1 on Distributor Doctor. I like the 123, but I also like originality. Martin does top notch work, for a decent price.
#7 Re: Distributor
Post by rswaffie » Fri Oct 21, 2016 7:26 pm
Yep, had my one sorted by Dizzy Doctor and he made a great job of it. It looks brand new.
