Series 2 aesthetics
MarekH
#241 Re: Series 2 aesthetics
Post by MarekH » Wed Mar 04, 2020 6:51 pm
The v12 in the s3 from 1971 was more thirsty than the 6 cylinder car with its straight 6 and with a 3.56 rear differential, it had a very low range to boot. This meant a larger fuel tank was required and that is why the boot does not taper upwards as with the earlier cars.
I doubt that Jaguar realised all of that when the s2 came out, so it's probably the other way around:- the same Lucas lights were kept but the tailboard was removed as the cheapest and easiest way to design in the larger needed fuel tank.
288gto
Russia
#242 Re: Series 2 aesthetics
Post by 288gto » Fri Mar 27, 2020 10:04 pm
A little bit of an update. The Elan lights are now fitted.
#243 Re: Series 2 aesthetics
Post by Gfhug » Sat Mar 28, 2020 10:06 am
Simon, that looks very nice :yellow:
The slimmer central bumper works well, another good idea :salute:
Jeff Cecil
#244 Re: Series 2 aesthetics
Post by Jeff Cecil » Sat Mar 28, 2020 12:58 pm
1954Etype
#245 Re: Series 2 aesthetics
Post by 1954Etype » Sat Mar 28, 2020 1:04 pm
Looks lovely but I’m more concerned about that white prop holding the boot lid open. I mean at least paint it in body colour!
Angus 67 FHC 1E33656
61 OTS 875047
MarekH
#246 Re: Series 2 aesthetics
Post by MarekH » Sat Mar 28, 2020 1:47 pm
Dear Simon,
How much does a set of Elan lights cost please, if you don't mind my asking?
288gto
Russia
#247 Re: Series 2 aesthetics
Post by 288gto » Sat Mar 28, 2020 2:22 pm
Thanks chaps,
Marek,
I'd already bought the S2 complete units from Barratts so just needed the lenses. They were about £40 each.
The light housing is basically the same but without the reverse light bulb holder so I just added holders from RS Components which were £7 for 10.
I decided to swap the bullet connectors for Supaseal ones to prevent water ingress and also so the connections were less likely to get muddled up.
I like idea of integrated led units but decided to go the route of retaining individual bulbs just incase they ever need replacing.
Jeff,
I'll take more pics when I get chance. They original lamp backing was used but the mounting holes altered to allow the lamp to tuck up under the bumper better and move inboard slightly. I then made black powder coated fillets to fill the gaps at the side with rubber seals.
Angus,
I can't tell you how much it annoys me that the boot lid comes to rest at 3/4 open. I spent ages (days) aligning the boot lid and the latch so it's all perfect only to find it probably needs an extra spring :cussing: A job for you when comes to you. Your guys can probably do it blindfolded. :yellow: and still not worry about chipping or scratching something.
MSM
#248 Re: Series 2 aesthetics
Post by MSM » Sat Mar 28, 2020 2:37 pm
Dear Simon,
I'm sure Marek knows that the answer is not cheap.
https://www.holden.co.uk/p/lucas_l807_t ... lamp_lotus
Mike
1969 S2 FHC
Jeff Cecil
#249 Re: Series 2 aesthetics
Post by Jeff Cecil » Sun Mar 29, 2020 2:26 pm
288gto
Russia
#250 Re: Series 2 aesthetics
Post by 288gto » Sun Mar 29, 2020 2:57 pm
Hi Jeff,
No drilling into the body. Everything I do in terms of "mods" on the car is with the proviso that it is reversible.
It was my intention to get the fillets painted body colour and use a different seal but Covid 19 got in the way of that plan. To make the best of the next 12 weeks I want to press on and get as much built up as possible and tested/working. I can always come back to the lights at a later date.
The filler pieces are attached to the existing bracket for the lights.
A few more pics as requested.
Jeff Cecil
#251 Re: Series 2 aesthetics
Post by Jeff Cecil » Sun Mar 29, 2020 3:20 pm
Jeff Cecil
#252 Re: Series 2 aesthetics
Post by Jeff Cecil » Fri Apr 24, 2020 4:27 pm
288gto
Russia
#253 Re: Series 2 aesthetics
Post by 288gto » Fri Apr 24, 2020 6:15 pm
Cheers Jeff,
Yours definitely follow the curve of the body better. All that is needed ( in my humble opinion ) is some sort of filler piece where the arrow is pointing to make them perfect.
Jeff Cecil
#254 Re: Series 2 aesthetics
Post by Jeff Cecil » Fri Apr 24, 2020 8:45 pm
jonj55
#255 Re: Series 2 aesthetics
Post by jonj55 » Tue Feb 16, 2021 1:49 am
Jeff Cecil wrote:
Wed Jul 24, 2019 1:22 pm
johnetype wrote:
Sat Jul 20, 2019 9:16 pm
If you're looking for comments on atheistics, it's got to be about the super wide Series 2 rubber bumper to body seal. Far from worrying if the number plate is straight, change that rubber strip for the Series 1 narrow one today. :bigrin:
John, thanks for pointing that out. The wife wanted to take a trip to the mountains (Blue Ridge Parkway) here in our state this weekend. I told her there is no way we can go because of the very grossly wide rubber on the bumper. Maybe this is an atheistics? problem rather than an aesthetics problem. Either way, I'm keeping the car in the garage until corrected. Good eye!
@Jeff Cecil
Thanks for linking this on BAT. I can't send you a private message, but where in NC are you? I'm near Asheville (Brevard). Maybe I could see the lights in person sometime.
You can PM through this forum.
Jon
1970 E-type
Family-owned 50 years
Jeff Cecil
#256 Re: Series 2 aesthetics
Post by Jeff Cecil » Tue Feb 16, 2021 4:00 am
Maph2
#257 Re: Series 2 aesthetics
Post by Maph2 » Wed Feb 24, 2021 8:08 am
Matt
S2 2+2 usa import, manual, Oct 1969 built
MarekH
#258 Re: Series 2 aesthetics
Post by MarekH » Wed Feb 24, 2021 7:25 pm
Matt,
Are you trying to do this....
side view small.JPG (206.81 KiB) Viewed 23524 times
Ready made side by side indicators and stop light lenses are available if you want them.
The white reversing lights are also wired up as doubled up additional red (stop) lights.
Jeff Cecil
#259 Re: Series 2 aesthetics
Post by Jeff Cecil » Thu Feb 25, 2021 12:24 am
MarekH
#260 Re: Series 2 aesthetics
Post by MarekH » Thu Feb 25, 2021 8:25 am
Jeff,
we don't know what Matt is thinking. All he has told us is that he has a US import and all-red lenses. In the UK, indicators have to be amber. Amazingly, there are no pictures of rear lenses with a vertical split of indicator and stop light to match the US spec chrome housings anywhere posted on his thread - until now.
