Help with the indicator switch
ChrisCtype
#1 Help with the indicator switch
Post by ChrisCtype » Tue Sep 14, 2021 1:15 pm
My car did not come with an indicator/horn switch so I purchased one from Martin Robey, now I believe I have traced and worked out the wiring but I'm sure some on can answer my question below ref the black cable.
This is how I have wired the switch
Switch ......................... loom......................part/item
Black (long wire)...................... Black.................... horn
Purple (long wire)..................... purple................... horn
Horn works
Blue/White............................ Blue/white..................headlight flash
Brown.............................Purple....................headlight flash
Green/blue........................Black/Red..................LH indicator warning light
Green Yellow......................Black/white................RH indicator warning light
Green/red.......................Green/red....................LH indicator circuit
Green/white....................Green/white.................RH indicator circuit
Light Green/brown.............Light green/Brown
Black............................ Green (so this connection is my concern)
So my issue is the last connection black on the switch in my mind indicates an earth but green in the loom is a 12v feed, is this correct?
hopefully someone can confirm
Chris
Series 2 FHC, + C type replica
