abowie wrote: ↑Thu Jul 14, 2022 11:24 pm
TexasJagMan wrote: ↑Thu Jul 14, 2022 4:04 pm
Thanks to all for your help.
I'll get the tap ordered.
Having seen my old post wait until I can measure one properly for you!
The 4BA screws are on the HS8. I'll need to find an HD8 to check for you.
I don't have an E Type HD8 at home to check.
I DO have a box of HD8s from Mk10 etc. Both the threads on the jet housing and the screws are DEFINITELY 4BA.
BUT, you can screw a 4BA screw into a 3BA die nut because they have very similar TPI. This might explain why I got the thumb nuts to go onto the throttle screws in my old post.
If you have a vernier caliper, the diameter of the throttle screws I have is 0.136". The studs on the back of a tacho are 0.156".
Here's a picture of the two side by side, with dies on them.
So I'm fairly confident that 4BA is correct, but I don't have an E type at hand to measure, sorry.
For safety's sake maybe order a 3BA tap as well. Then you can make thumb nuts for the instruments; always a plus.
