Gearbox leak
Colfod
#1 Gearbox leak
Post by Colfod » Fri Mar 17, 2023 1:47 am
Is there a front oil seal on the 4.2 gearbox? I replaced the seal on the clutch housing but still have a leak. I have a 1970 E Type coupe.
Allrand
#2 Re: Gearbox leak
Post by Allrand » Fri Mar 17, 2023 6:53 am
What, where is the seal on the clutch housing?
Randall Botha
'64 3.8 fhc & '51 Mk 7
Simonpfhc
#3 Re: Gearbox leak
Post by Simonpfhc » Fri Mar 17, 2023 7:17 am
As well as the seal in the clutch housing, there is also a large gasket. It covers the whole front face of the gearbox and seals up against the rear of the clutch housing.
Are you sure the leak is from the gearbox and not the dreaded rear crank rope seal!
62 3.8 FHC
91 Porsche 928GT
68 S1 OTS full resto....will be for sale!
Colfod
#4 Re: Gearbox leak
Post by Colfod » Fri Mar 17, 2023 4:42 pm
The seal for the housing is behind the clutch fork. I have the Terry’s Jaguar rear main oil seal conversion that replaces the rope seal. I replaced the large gasket, but saw there is a front seal mentioned in the parts catalog for the gearbox. Did not see one when I took it apart.
Jack the lad
#5 Re: Gearbox leak
Post by Jack the lad » Sat Mar 18, 2023 7:37 am
The first thing is to decide what type of oil is leaking out. Is it gearbox oil or engine oil, I'm sure you know how to decide, if not just ask. When we know the oil type then we can give you a list of possibilities for a fix. :bigrin:
angelw
#6 Re: Gearbox leak
Post by angelw » Sat Mar 18, 2023 8:15 am
The only seal at the front area of the Gearbox is the Lip Seal pressed into the face of the Bell Housing that interfaces with the front face of the Gearbox; there are no others at the front of the Gearbox.
When I refurbish a Jaguar Gearbox, I use a Front Bearings that is equipped with shields. I remove the rear shield of the bearing that faces to the rear and leave the front shield in place. This allows oil into the bearing for lubrication, but greatly limits the amount of oil that the First Motion Shaft seal is exposed to.
As other have said, determine conclusively the actual type of oil that is leaking outl
