Having discovered that there was a crack in this copper tube where it joins the soldered nipple at the carburettor end, I've managed to drop the nipple which I was about to resolder to the tube. An extensive search has failed to locate this nipple, so Ideally I'm looking for a replacement. So, does anyone on here know what size this nipple is? I'm sure they are readily available possibly from model engineering shops. I know that the complete tube assembly is readily available, but I would prefer to repair if poss.
Thanks in advance
Andy
Vacuum advance pipe
Jack the lad
#2 Re: Vacuum advance pipe
Hi Andy, if you put a search into ebay for item number 391808026028 you will locate the part you desire, cheers John.
#3 Re: Vacuum advance pipe
Hi Jack
I decided to bite the bullet and order a replacement tube assembly from MR. I was amazed at the difference in price between the leading suppliers.
Thanks for your input.
ATB
Andy
ATB
Andy
Andy
1970 S2 FHC
1965 SB Corvette Ragtop
1970 S2 FHC
Jack the lad
#4 Re: Vacuum advance pipe
Hi again Andy,
did you give D. Manners a try, I use them quite a lot. Please give us a brief idea of the various suppliers and their prices on your pipe for future ref. cheers John.
#5 Re: Vacuum advance pipe
I sourced my replacement from Martin Robey who, suffice to say, were considerably cheaper than the other major suppliers.
Andy
1970 S2 FHC
1970 S2 FHC
