Today I changed points and condenser. Every time I do this, I worry that I will drop a screw down the inside of the distributor.
What do forum members do to reduce this risk?
1. Use a magnet.
2. Cover gaps with a cloth
3. Use thick grease on the screwdriver
4. Fit electronic ignition
5. Any other suggestions?
I used a combination of method 2 (the cloth) and method 3 (the grease), but I still wasn't totally confident....
Many thanks in advance for your advice.
Changing contact breaker points
#2 Re: Changing contact breaker points
Electronic here makes it all pointless
#3 Re: Changing contact breaker points
Note the rotor arm position in the dizzy....slacken the dizzy clamp nut.....pull out the dizzy.....then take it to the bench to fit the points...or by the side of the road....refit..easy.....Steve
#4 Re: Changing contact breaker points
Brilliant, simple, easy when you know how. I'll do it that way next time.
Many thanks, Steve
Many thanks, Steve
John L
1969 S2 OTS RHD
1969 S2 OTS RHD
