Pre-cut key
Rafa73
Brazil
#1 Pre-cut key
Post by Rafa73 » Fri Oct 20, 2023 9:25 am
Gentlemen,
Thank you for having me in the group.
Can I get a pre-cut ignition key to my E-Type somewhere, by providing the chassis number?
Thanks,
Rafael, from Brazil.
tim wood
#2 Re: Pre-cut key
Post by tim wood » Fri Oct 20, 2023 11:27 am
I don’t think that you can.
What year and model is your car?
Monkeyfinger
#3 Re: Pre-cut key
Post by Monkeyfinger » Fri Oct 20, 2023 2:21 pm
Its unlikely - in any case, quite possible the lock has been replaced in the past so it wouldn't help.
Rafa73
Brazil
#4 Re: Pre-cut key
Post by Rafa73 » Fri Oct 20, 2023 2:52 pm
Thank you for your input.
It’s a 1969 convertible.
I’m a Rolls-Royce/Bentley enthusiast (I’m new to Jaguar) and I have ordered several keys from Crewe, not just for the ignition, but even for the wheels, and it always worked. They keep the codes on file.
I guess I’ll have to buy a blank and take it with a lock cylinder to a locksmith for him to match.
max-it-out
#5 Re: Pre-cut key
Post by max-it-out » Fri Oct 20, 2023 2:55 pm
If you can`t find a new key , you can always buy a new ignition lock which comes with it`s own key .
1968 series 1.5 roadster
#6 Re: Pre-cut key
Post by mgcjag » Fri Oct 20, 2023 2:55 pm
There are ads on ebay for keys cut.. you send a close up photo of the key.. they then kut a new key from the photo... worked for me..Steve
Rafa73
Brazil
#7 Re: Pre-cut key
Post by Rafa73 » Fri Oct 20, 2023 3:08 pm
I just bought the car and it does not have any keys.
In regards to buying a lock, then I’d need a set of locks…
No problem I have an excellent locksmith, he’ll cut a blank for me.
Thanks everyone!
Rafa73
Brazil
#8 Re: Pre-cut key
Post by Rafa73 » Fri Oct 20, 2023 9:38 pm
Just found this:
https://www.ebay.com/itm/303981495374?m ... media=COPY
Seller claims the key code is written on the locks.
Allrand
#9 Re: Pre-cut key
Post by Allrand » Sat Oct 21, 2023 7:16 am
It would help if you put your car model in the signature area. My 3.8 has the key code on the ignition switch.
Randall Botha
Rafa73
Brazil
#10 Re: Pre-cut key
Post by Rafa73 » Sat Oct 21, 2023 11:02 am
I’m sorry, I’m not familiar with the models yet.
All I can say is it’s a 1969 convertible.
#11 Re: Pre-cut key
Post by mgcjag » Sat Oct 21, 2023 11:13 am
Straight six 4.2 will be a S2....your ignition/steering lock key will be a different key to the door locks....Steve
Rafa73
Brazil
#12 Re: Pre-cut key
Post by Rafa73 » Sat Oct 21, 2023 1:19 pm
Thanks Steve, that’s helpful information m, as I just bought some ignition blanks on eBay. Now I’ll look for some door blanks. Thanks again!
#13 Re: Pre-cut key
Post by Heuer » Sat Oct 21, 2023 1:23 pm
The key code will be on the lock barrel: viewtopic.php?p=34688#p34688
Rafa73
Brazil
#14 Re: Pre-cut key
Post by Rafa73 » Sat Oct 21, 2023 2:54 pm
Wow, lots of precious information on that page.
I’ll read it carefully, and I’ll probably be back with some doubts.
Thanks much!
