2+2 door glass
DT
#1 2+2 door glass
Post by DT » Sat Oct 27, 2012 3:54 pm
I would welcome some help
Stripping down my series 2 2+2 for body rebuild and paint
Just got stuck on how to remove the door glasses
Workshop manual tells me there is a stop to undo but can't find one
Can someone tell me how to do it please
Many thanks
MarekH
Post by MarekH » Sat Nov 03, 2012 2:08 pm
The OTS/roadster has a stop towards the rear of the door to prevent the glass getting too high and causing trouble chipping the glass were the door to be shut with the top down.
If the manual was written for a roadster, then perhaps this would explain the odd wording which won't apply to the coupe version.
Post by christopher storey » Sat Nov 03, 2012 6:39 pm
To get the glasses out, it is usually essential to remove the frame at the same time . The basic technique is to leave the door glass about 2/3 to 3/4 of the way up , release the frame fastenings which are drive screws along the top rail and nuts and bolts at the base of the legs of the frame . Then get an assistant to slowly ease the frame upwards while you raise the door regulator with the handle. there will come a point where the regulator wheels will reach the end of the channel and can be slipped out of it. Once this has been achieved, the whole frame and glass can be lifted off the door altogether.
DT
Post by DT » Sun Nov 04, 2012 10:26 am
Many thanks for this information
The workshop manual clearly on refers to the roadster which does not apply
Have now removed glass as suggested
To release the winder I also undid the 4 bolts holding the winder in the centre of the door
Now back to stripping car and finding rust!
Thanks once again
