Rev counter indicating not enough RPM
r.ludeke
Netherlands
#1 Rev counter indicating not enough RPM
Post by r.ludeke » Thu Aug 11, 2016 8:10 pm
Hello, my rev counter is not idicating the correct amount of rpms. It looks like half of what it should be , at 60 mph (100km) it is indicating about 1500 rpm. I am using a electronic ignition, Powerspark 45D6 but had the same problem when driving with the conventional distributor. My rev counter is a RVI 4614/01.
My idea is to change the inner work to rvc, hoping that will solve the problem? Did anybody encounter the same problem?
Kind regards, Rolf
#2 Re: Rev counter indicating not enough RPM
Post by mgcjag » Thu Aug 11, 2016 9:17 pm
Hi Rolf..have a look here....check your wireing https://www.spiyda.com/magento/index.php/tacho-wiring
r.ludeke
Netherlands
#3 Re: Rev counter indicating not enough RPM
Post by r.ludeke » Thu Aug 11, 2016 9:49 pm
Hi Steve,
Thanks for your reply. Spidya is where i am planning to buy the conversion so i saw this page. I think my wiring is ok and the problem is inside the tacho because the problem already existed with the the original lucas distributor.
#4 Re: Rev counter indicating not enough RPM
Post by Gfhug » Fri Aug 12, 2016 7:29 am
Rolf, an option to consider is that Spiyda will do the conversion for you if you don't want to do the work yourself. They did it for me.
r.ludeke
Netherlands
#5 Re: Rev counter indicating not enough RPM
Post by r.ludeke » Fri Aug 12, 2016 8:01 am
Thanks Geoff, but i think i will give it a try. What was the reason you decided to do the conversion?
#6 Re: Rev counter indicating not enough RPM
Post by Gfhug » Fri Aug 12, 2016 12:48 pm
The tacho was reading low, just enough to suggest I had a 3.54 diff not the 3.07 I did have. I was comparing the rpm to GPS speed. Now it has been modified all seems fine.
r.ludeke
Netherlands
#7 Re: Rev counter indicating not enough RPM
Post by r.ludeke » Fri Aug 12, 2016 2:54 pm
That looks like the 1500rpm mine gives when driving 60 mph. (I wish it was true) I will order a conversion set this weekend. Thanks for your replys.
#8 Re: Rev counter indicating not enough RPM
Post by Gfhug » Fri Aug 12, 2016 4:39 pm
Oops, I should have said reading HIGH.
However, both yours and mine are/were faulty
r.ludeke
Netherlands
#9 Re: Rev counter indicating not enough RPM
Post by r.ludeke » Fri Aug 12, 2016 5:40 pm
We will keep it to ourselves :wink:
