Heater Flapper Stay and Air Intake Bonnet
willyspu
#1 Heater Flapper Stay and Air Intake Bonnet
Post by willyspu » Thu Nov 02, 2017 3:57 am
I am working on restoring my heater box and have 2 questions:
1. On the bar that holds the flapper, opposite of the cable side, I have a fitting that looks like it has a set screw inside. I have seen pictures with a bolt in there. My question is, did Jaguar use a set screw that went into the fitting? (See attached picture.)
2. For a Series II, was an air intake for the heater box used? Mine seems to be missing.
Thanks for the help!
Jim
1R11203
Jim
Series II
1R11203 Regency Red
mark10337
Switzerland
#2 Re: Heater Flapper Stay and Air Intake Bonnet
Post by mark10337 » Thu Nov 02, 2017 9:34 am
Hi Jim
Welcome along to the forum from another S2 OTS in Regency Red.
Yes is the answer to both your questions. Jaguar did use a setscrew and from the picture in your welcome post, unless it is just out of camera shot, the air intake for the heater is missing on the bonnet.
http://www.sngbarratt.com/CatalogueProd ... 7229&a=620
The duct is #10, with the opening on panel #19.
http://www.sngbarratt.com/CatalogueProd ... 29&a=15530
On the opening goes the duct to the heater box, #45
Interestingly it also looks like the alternator is in the position when aircon is fitted, but you don't have it fitted in the interior.
-Mark
EtypeMoneyPit
#3 Re: Heater Flapper Stay and Air Intake Bonnet
Post by EtypeMoneyPit » Thu Nov 02, 2017 10:48 am
Hi Jim, here is a good photo showing the heater duct (SNG #10) mentioned by Mark. Photo is of an early S2 bonnet (1R25275). Not sure whether it was changed for later S2 cars to clear new position of the a/c compressor. Regards, Kris
Kris
1968 S2 FHC
1978 VW T2B
mark10337
Switzerland
#4 Re: Heater Flapper Stay and Air Intake Bonnet
Post by mark10337 » Thu Nov 02, 2017 1:54 pm
by the way, the setscrew is a UCS113/3R
Coarse threaded setscrew. Hex head. Thread diameter 1/8" 32 TPI. 3/8" long.
-Mark
willyspu
#5 Re: Heater Flapper Stay and Air Intake Bonnet
Post by willyspu » Thu Nov 02, 2017 9:37 pm
Thanks everyone for the information and links!
Jim
Series II
1R11203 Regency Red
willyspu
#6 Re: Heater Flapper Stay and Air Intake Bonnet
Post by willyspu » Fri Nov 03, 2017 4:36 pm
Is this the proper style Heater Air Inlet for a Series 2 built 12/1969? It looks like it has the proper bolt hols for my air intake on the bonnet.
http://www.sngbarratt.com/ProductDetail ... a7ddeb246c
Mark, you are correct, my 1R11203 does not have a/c or power steering but has the alternator facing in that position. I am fairly sure it is all original as it was purchased by my mother-in-law new 12/1970. Although, it has had a few repairs due to accidents.
Jim
Jim
Series II
1R11203 Regency Red
mark10337
Switzerland
#7 Re: Heater Flapper Stay and Air Intake Bonnet
Post by mark10337 » Sat Nov 04, 2017 9:22 am
Yes, that is the correct part for the heater air inlet.
You will need
1x BD.22480 Extension Assembly, in Bonnet, for Heater Air Intake
1x BD.28378 Seal, Rubber, for Air Intake Extension
5x UCS.125/6R Setscrew, securing Extension Assembly
5x UCN.125/L Nut, on Setscrews
3x BD.542/3 Washer, Special (oval), under Setscrews
5x FG.104/X Washer, Spring, under Nuts
You also appear to be missing the short rubber sealing strip underneath it on the mudguard (#49 & #50)
1x BD.20816/2 Seal (Rubber) between Bonnet L.H. Rear Diaphragm and Frame Side Member
1x BD.20736 Fixing Strip, for Rubber Seal
4x BD.1814/6 Pop Rivet, securing Fixing Strip
and possibly the one to the side but I can't see in the picture
1x BD.20816/1 Seal (Rubber) between Bonnet L.H. Valance and Frame Side Member
1x BD.20735 Fixing Strip, for Rubber Seal
The alternator does seem to be an anomaly. I've seen plenty of late 69 and 70 cars with the alternator fitted by the exhaust manifolds when the aircon was not fitted. But it works and will be on factory parts so no big deal really.
-Mark
willyspu
#8 Re: Heater Flapper Stay and Air Intake Bonnet
Post by willyspu » Sun Nov 05, 2017 7:00 am
Thank you Mark!
Jim
Jim
Series II
1R11203 Regency Red
