Kienzle clock
spotdoc67
#1 Kienzle clock
Post by spotdoc67 » Sun Dec 17, 2017 8:29 pm
I have a 1969 series 2 FHC that has a Kienzle clock fitted
A couple of questions...
Is that the correct clock for the car?
It doesn't work. How can I test it and repair it?
Tom
Bfastr
#2 Re: Kienzle clock
Post by Bfastr » Mon Dec 18, 2017 3:49 pm
the Series 2 came with a Smiths clock.
CET-3201/00 for FHC up to 1R24424 1R26834 ( this clock had a little battery on its back)
CTE-3107/01 for FHC from 1R24425 1R26835 ( this clock ran off the +12v car battery)
from the front they appear very similar with a change in the model number and "Made in UK" moved from under the 6 to up in the top right over the numeral 1
the only source I know of is Jaguarclock.com to fix or replace the mechanism with a modern one.
Bob F
69 S2 E-type OTS LHD
#3 Re: Kienzle clock
Post by malcolm » Mon Dec 18, 2017 5:15 pm
I had the clock shown in the picture above. Had a small battery. Checked and replaced the connectors with a bit of solder. Still didn't work. Bashed it on the table, and away it went. Been going ever since (with the occasional battery change)
Nickleback
#4 Re: Kienzle clock
Post by Nickleback » Mon Dec 18, 2017 5:22 pm
Hi Tom,
Being based in the UK, you will need to send it to Mike Eck via Coolcat in America to get it repaired.
Here's the link:
www.coolcatcorp.com
and the jaguarclock link is near the bottom on the index.
Just about to send mine off to him to as it stop starting a lot and is now unreliable :roll:
Mike,
1970 S2 FHC 2R28165
