Hi there, I am getting oily wet fouling on the 3rd cylinder from the front (technically not sure what cylinder number that is) I assume it’s probably either a head gasket or a valve guide.
Any advice on which it’s most likely to be or if there is another option I have missed?
Wet plug fouling
#1 Wet plug fouling
Sydney Australia
Current
Jaguar Red Series 2 2+2 XKE 1969
Jaguar Italian Racing Red F-Type S 2014
Jaguar XJ6 Vanden Plas dark green 1985
Jaguar XJS V12 Silver 1987
Previous of interest
Jaguar XJ6 Sovereign series 3
MGA 1959
Current
MGA 1959
Nickleback
#2 Re: Wet plug fouling
Have you tried moving the plug to another cylinder to see if the problem moves with it, also you could do the same with the HT lead & cap to check first ?
Mike,
1970 S2 FHC 2R28165
1970 S2 FHC 2R28165
#3 Re: Wet plug fouling
Have replaced the plug several times. All new 123 distributor, new leads, new coil.Nickleback wrote: ↑Sat Mar 10, 2018 7:11 amHave you tried moving the plug to another cylinder to see if the problem moves with it, also you could do the same with the HT lead & cap to check first ?
Sydney Australia
Current
MGA 1959
Current
MGA 1959
#4 Re: Wet plug fouling
Can’t help with the problem but can help on your cylinder numbering!
That’s cylinder 4 They’re numbered from the bulkhead to the front of the car.
I’m sure a techie bod will be along in a minutewith ideas on the issue......
Paul Brazier. S2 FHC 1970, silver with blue leather. Oh, and a S1 prototype Lotus Elise and a Ferrari 488 GTB
