S2 OTS speedometer on Import from USA - Diff Ratio
jmgtaylor
#1 S2 OTS speedometer on Import from USA - Diff Ratio
Post by jmgtaylor » Fri May 28, 2010 8:05 pm
I understand that there are different speedos depeinding on the diff ratio.
Whats the easy way to find out, is it marked anywhere on the diff, i can get easy enough access.
Post by Heuer » Sat May 29, 2010 11:09 am
There should be a tag on the diff showing the ratio - e.g. 43/13 for a 3.31 diff (dividing one into the other will give you the ratio). The speedometer codes are here: http://etypeuk.com/forum/viewtopic.php?t=951
